![]() | Home > General > Engine question |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Did the plugs come out OK or did they have the heads off? |
Big T Member Since: 23 Dec 2012 Location: Stoke on Trent Posts: 9 ![]() ![]() ![]() |
No the head didn't come off mate but they did struggle to get one out and had to drill to get it out but as a precaution I also had a oil change straight after to be double safe |
I would get it back to a garage pdq. Tapping tappets would indicate loss of oil pressure to the top end to me if all of a sudden they tap. I know v6 is bit noisey when cold but there shodnt be an audible tapping 2x TDV6. SE and HSE. Both returned to sender with issues👀
Ile do just that thank you but without sounding to thick wouldn't a warning light come on or is it a simple fix for this problem |
May be enough to put light out but not enough to keep tappets filled. 2x TDV6. SE and HSE. Both returned to sender with issues👀
