Home > Maintenance & Modifications > Supercharger oil change.
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Hi, anyone out there done this? No mention of needing to do in the servicing records but been advise to change the oil at some point. Thanks in advance.
Post #377243 Sun Mar 17 2013 9:26pm
shepp
hello
apparently sealed for life, but apparently it is possible to change
I think the sc in the rrs is the same as the M112 eaton that the jags and many others use,
service kit below but also powerhouse in sheffield do one.
http://www.ebay.co.uk/itm/Range-Rover-Supe...0983412752
http://www.ebay.co.uk/itm/Eaton-M112-super...0698921204
the below link may assist with changing the oil
http://www.mustangevolution.com/mustang-ar...04-cobras/
This is also worth a look.
http://www.jaguarforums.com/forum/xj-x308-...tes-57136/
The best thing you can do for your sc is to check the coolant pump is wired the correct way, ensuring correct cooling, most were wired backwards.
Hope this bumf all helps
Post #377252 Sun Mar 17 2013 10:00pm
SCdavies
Many thanks. Coolant pump wiring? really? do you the correct way? wire colours? Cheers
Post #377356 Mon Mar 18 2013 3:41pm
shepp
hello scdavies
Have a look at my gallery for coolant pump info, just added it. Mostly in the UK you will not knotice as it does not get warm enough, and having an sc you probably drive like miss daisy most of the time.
I only had reduced power a couple of times in the uk, in very warm weather, but whilst in Monaco the sc always overheated due to 80mph and long up hill streatches. I bought a new coolant pump and filed the lug off the pump so the connector could be reversed.
let me know how you get on with sc oil change Thumbs Up [/img]
Post #377399 Mon Mar 18 2013 8:21pm
shepp
hello
quick guide for replacing coolant pump
http://www.rrsport.co.uk/forum/topic27554.html
Post #378028 Sun Mar 24 2013 11:34am
USAFBuckeye
United States 2007 Range Rover Sport Supercharged Stornoway Grey
Besides seeing that it's wired wrong, is there any indication (mechanically/performance) that it is?
Guess there's really no way to know if there's been any mechanical damage done due to an improperly wired pump, right?
Thanks in advance for the answers! Thumbs Up '12 RRS SC
'07 RRS SC
'11 Honda Odyssey Touring Elite (sigh...)
Gone, but not forgotten
'02 RR
'05 LR3 SE7 (Best off-road rig I've ever had) let her go @ 100K miles
Post #379133 Sat Mar 30 2013 1:53am
shepp
hello USAFBuckeye
sorry about the delayed response, been away for a few days,
Under normal use there should be very little heat related damage, as the impeller on the pump is still pumping round the coolant, just not as fast as it needs to when under great load.
I only noticed, when getting reduced power message on display, on very hot days in the uk and when I had been drivingly spritely. Whilst in Monaco, where the speed limit is approx. 80mph and the roads, long and steep. I constantly had reduced power due to sc getting warm, but due to the rrs putting the vehicle in reduced power mode, the sc cools very quickly minimising any chance of damage.
In hot weather I now get better mpg since changing the sc coolant pump, ive even had it up to an average of 21mpg on a tank (not that mpg is an issue on an sc Whistle )
Post #379265 Sun Mar 31 2013 8:40am
USAFBuckeye
Hey Shepp,
No worries and thanks for the reply. I had no idea this was an issue for the RRS, but thanks for posting such detailed and helpful instructions! '12 RRS SC
'07 RRS SC
'02 RR
Post #379326 Mon Apr 01 2013 12:28am
