Home > General > RR sport transmission fault
steverrsport
Hi, don't know what the code was but the current when it comes on dash says transmission fault
The rac plugged it in and it said there was a current fault which was the torque converter and may go into limp mode and also an underlying fault of EGR valve Sad
Post #377285 Mon Mar 18 2013 9:07am
simple1
You should have got an inspection sheet on which the mobile should record the actual codes the machine found. The code is far more important than the error so a repairer can diagnose the fault. Hopefully the mobile didn't clear the codes, just simply read them. The error diagnosis by machine is only as good as the software writer and often a fault code can be caused by other issues so the error is not gospel where as the code is. Clear as mud eh Rolling Eyes 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #377289 Mon Mar 18 2013 9:21am
Disco_Mikey
As above. Just because one fault is stored, does not mean that component is faulty.
A good deal of experience comes into diagnosis now and then (especially with the LR brand Rolling Eyes )
I suspect the your best bet now would be to drive the car until the fault happens, and take it to a specialist with LR specific diagnostics, and get the faults re-read, and report back Thumbs Up
EDIT: Unless you have a warranty. Then let them deal with it...
Post #377291 Mon Mar 18 2013 9:27am
steverrsport
Ok, But as we have had the car less than 24 hours and has sat out side the house since 4 oclock on saturday afernoon and only getting it 2 hours previous it is going back on a low loader !
RAC report sates not to be driven.
Post #377293 Mon Mar 18 2013 9:53am
steverrsport
Well all sorted, getting my money back tomorrow as over a £1000 + repairs, they wasn't prepared for stratstone to do the work. my prayers answered... Very Happy
Post #377329 Mon Mar 18 2013 2:17pm
PEACHY
Thumbs Up That`s what you call a near miss - what's your plans now Shocked 16MY Estoril Blue SVR.............
Post #377344 Mon Mar 18 2013 3:32pm
steverrsport
well i will keep looking and maybe i will find the rite one, as the it was the hse in java black and cream leather thats what combination i want or maybe the stornaway grey and cream leather, but hse will be the minimum spec that i will want. Happy days
So if you or any one knows of one (A GOOD ONE) LET ME KNOW Smile
Post #377349 Mon Mar 18 2013 3:51pm
Bodsy
Site Sponsor
If you find a local one and you want its fault codes read/checked before buying, give me a shout. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #377370 Mon Mar 18 2013 6:22pm
steverrsport
Thank you very much, it would be appreciated. Smile
Post #377372 Mon Mar 18 2013 6:25pm
pjb
Hi Steve,
Once youv'e got your money back might be worth putting the vehicle details on the forum so another punter does not buy without ensuring its repaired properly as obviously the garage do not intend doing that !
Good luck with you search, might be more expensive but go for main dealer with LR warranty lots of others on here caught by none LR warranty with more exclusions than than a cheap Ryan Air flight.
Good luck Paul
L405 Loire Blue
Swift Conqueror 645
Abarth 500c
Post #377374 Mon Mar 18 2013 6:50pm
steverrsport
Hi all, just to let you know i received a full refund today from the garage in Willenhall .
They said they had done the faults, it turned out to be just an oil and filter change on the gearbox!!!
reg no - DN06EYC
IT HAS NOW BEEN PUT BACK ON SALE AT AN EXTRA £1000 !!!!!!!!!!
Thanks all for your help.
Steve
Post #377530 Tue Mar 19 2013 9:59pm
simple1
That is an expensive oil change. One wonders if the first long journey might relight the warning icon Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #377556 Wed Mar 20 2013 8:22am
