Home > Technical > Auto windows up?
AndyBrew
United Kingdom 2013 Range Rover Sport SDV6 HSE Luxury Fuji White
Auto windows up?
Is there any setting that prevents the windows from closing using the single pull on the switch, I am pretty sure that the windows would close automatically by simply pulling switch all the way up, however they now need a constant hold on the switch until they are fully closed???
Maybe linked to the reprogramming done for my timed climate??
Thanks,
Andy
Post #377131 Sat Mar 16 2013 5:49pm
mse
Have a read of your manual Thumbs Up
If you are on about one touch closing...then you will need to re calibrate your windows, look in the manual - i think its fully close the windows and then press the switch (up) again immediately.
You will need to do it on the sunroof as well - very common after the CCF is reflashed. Mike
2014 Facelift Discovery
Post #377136 Sat Mar 16 2013 6:23pm
mse
Page 183
Quote:
WINDOW RESET
The windows will need to be reset if the battery
is disconnected, becomes discharged or power
supply is interrupted.
Reset as follows:
1. Close the window fully.
2. Release the switch, then lift it to the close
position and hold for 1 second.
3. Repeat the procedure on each window.
SUNROOF RESET
If the battery is disconnected or the power
supply is interrupted whilst the sunroof is
partially open, it will need to be recalibrated.
Once the battery is reconnected or the power
supply is restored, recalibrate the sunroof as
follows:
1. Switch the ignition on.
2. With the sunroof closed, press and release
the front of the switch. The sunroof will
move to the tilted position.
3. Press the front of the sunroof switch and
hold for 20 seconds.
4. After 20 seconds, the sunroof will begin to
move. Keep the front of the switch pressed
until the fully open/close cycle has
completed.
5. Once the sunroof has stopped moving,
release the switch.
The sunroof can now be operated as normal.
 Mike
Post #377137 Sat Mar 16 2013 6:27pm
AndyBrew
Mike you are a legend, thank you I'll sort it tomorrow Bow down
I think I owe you a couple of beers!
Post #377138 Sat Mar 16 2013 6:35pm
mse
No problem Thumbs Up Mike
Post #377139 Sat Mar 16 2013 7:02pm
