![]() | Home > General > List of gadgets. |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
Depends on the car model, SE, HSE, and if it was V6 or V8 as they all had differing standard and optional extras. 2x TDV6. SE and HSE. Both returned to sender with issues👀
| reid7774 Member Since: 12 Apr 2012 Location: Thurso Posts: 73
It would be on a 2.7 hse thanks |
| P7tey Member Since: 03 Oct 2012 Location: Devon Posts: 144
Try this post
HSE had different leather to SE and some had 18 and 19 inch wheels. Satnav and Bluetooth should be standard as was dynamic ride on 2006 model. Later dropped as an option. DVD and surround/ enhanced sound was an option, as was sunroof. Some 2007 cars had centre fridge as standard some didn't. My 2006 V6 did have it. Only other options were tow bar electrics and 20" wheels which on early cars required a steering rack change, after 2007 all cars came with heavier rack. 2x TDV6. SE and HSE. Both returned to sender with issues👀
| JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186
I asked my dealer if they could provide a spec sheet which lists standard and optional extras, however they said it wouldn't be possible. It's annoying because with my previous Mercedes, the dealer could provide me with the vehicle's datacard which lists the standard and optional extras the car came with.
| RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176
That's strange as my dealer was able to print out a detailed list of my spec...
Dealer system should be able to tell you via chassis number. When I spoke to dealer in Yeovil about trading mine in, the sales man was able to tell me all about the car and spec from readout. I also believe the options are coded on a sticker in the back of the service book. 2x TDV6. SE and HSE. Both returned to sender with issues👀
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
You can even do it yourself Mike
| All times are GMT |
