![]() | Home > General > Have I done the right thing?! |
| sagalout Member Since: 26 Feb 2013 Location: Harrogate Posts: 128 |
Quick update. Spoke to the dealer and they genuinely didn't know about the repair (pretty sure they would have just thrown away the invoice if they did!)
| shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948
I'm not sure you can Re-map a 61 plate 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
I think you can now:
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
In my opinion buy an RRS is like overtaking - if in doubt don't.
Sag, as you say the warranty is a grey area, if your turbo's go pop, who do you think will pay for new ones? If L/R reflash your ecu which they often do due to updates, you will lose your modified map, as mapping your model requires taking out your ecu and mapping it on the bench, do you really want to be doing this with your motor everytime you take it to the dealers |
hhmm, ok, sounds like I need to think the remap through a bit first. I didn't realise that the LR dealer may just update the map themselves and over write it.
Some mappers are prepared to put the modified map back on for free should it get wiped, might be worth asking your mapper if he offers this service. |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
Land rover are very clear a remap invalidates your warrant, if like me, your warranty is important, leave it. On the standard map Mike 2014 Facelift Discovery |
Ok, I may need to get friendly with the command shift! I used it a bit on the test drive and found I could just tap on of the paddles to activate it, but to put it back into 'D' do you just have to move the stick left and then right? I found from a proper stop, eg at traffic lights, take off was fine, but from a momentary stop or just crawling at low speed there was a bit of a delay. Not sure if this is gearbox lag or turbo lag. |
press the + paddle and hold to return to full auto |
Anyone with a moderate amount of computer knowledge and cheap technology can produce remaps and remapped 'chips'.
Yeah, I've decided against the remap.
| Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087
Enjoy |
| All times are GMT |
