Home > General > Advice needed please ! Check Engine Light on !
JimKim
Hi all
Was driving home this evening when the fuel light came on. Pulled in and filled to the brim (2.7v6) got back in switched on and the check engine came on and has stayed on (not flashing).
Anyone any ideas Big Cry
Thank you S, grey, all black int, s,steps, window tints, fridge, ff tv x 3.
Post #375021 Wed Feb 27 2013 7:48pm
simple1
You need to read the fault codes to know. Could be eleventy seven things. My guess is EGR valve as it sticks when hot but don't take that as gospel. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #375022 Wed Feb 27 2013 8:03pm
JimKim
Thanks mate I'll leave it over nite and see what it dose when cold Question S, grey, all black int, s,steps, window tints, fridge, ff tv x 3.
Post #375025 Wed Feb 27 2013 8:39pm
StuRRS
2007 Range Rover Sport TDV6 HSE Java Black
Had exactly the same 2 weeks ago, diagnosed by stealer as EGR valve faulty, dropped off this evening for replacement tomorrow, £370 to you sir Whistle
As Simple says could be a number of things.... Stu
2023 RRS p440e SE Dynamic
2018 Discovery 5 SDV6 HSE Santorini gone
2014 SDV6 HSE Santorini gone
2007 TDV6 HSE Java gone
2003 Discovery TD5 ES gone and missed
2008 Q7 gone
2005 X5 gone
2003 X5 gone
2000 Freelander 2.5 V6 gone- not missed!!
Post #375026 Wed Feb 27 2013 8:42pm
JimKim
Big Cry hope it's covered under warranty S, grey, all black int, s,steps, window tints, fridge, ff tv x 3.
Post #375027 Wed Feb 27 2013 9:01pm
My understanding is that anything that affects emissions will throw up the "engine light". 2012 SDV6 - it's missing a couple of cylinders
Post #375074 Thu Feb 28 2013 10:14am
simple1
There are two systems, the management light and the DIS which shows faults on the LCD display. There is not consistency to how these work. You can get a DIS fault which does or doesn't record in fault log. Same with light. When mine self distructed there was no light but a DIS message. When log was checked, one error for boost deviation was logged but was historical not current. So the system is not infallible. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #375077 Thu Feb 28 2013 10:32am
JimKim
Yep EGR Big Cry S, grey, all black int, s,steps, window tints, fridge, ff tv x 3.
Post #375143 Thu Feb 28 2013 6:29pm
StuRRS
PM'd you Stu
2008 Q7 gone
2005 X5 gone
2003 X5 gone
Post #375237 Fri Mar 01 2013 9:52am
Endjin
Scotland
JimKim wrote:
Yep EGR Big Cry
If your car is out of warranty then take it to an independednt to get this fixed. No point paying main dealer prices. I'm sure someone on here in your area could recommend a good one for you. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #375238 Fri Mar 01 2013 9:57am
JimKim
Endjin wrote:
JimKim wrote:
Yep EGR Big Cry
She's off to James French don't fancy mine being test drove at warp speed by Hartwells Whistle S, grey, all black int, s,steps, window tints, fridge, ff tv x 3.
Post #375333 Fri Mar 01 2013 9:07pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
What year is your RRS?
If it is <2007 you can blank off the EGR's. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #375337 Fri Mar 01 2013 9:31pm
JimKim
It's an 07 57 plate S, grey, all black int, s,steps, window tints, fridge, ff tv x 3.
Post #375338 Fri Mar 01 2013 9:36pm
JasM
It's an 07 57 plate
Not possible then, same year as mine. Sad
Did you notice any symptoms before the engine light appeared? Ie. Performance loss, poor MPG etc. 2014 L405 SDV8 RR Autobiography Cool
Post #375339 Fri Mar 01 2013 9:42pm
JimKim
JasM wrote:
It's an 07 57 plate
Nope nothing just wondering weather letting it get low on fuel triggered it although the light came on a mile from the garage so wasn't on fumes Question S, grey, all black int, s,steps, window tints, fridge, ff tv x 3.
Post #375340 Fri Mar 01 2013 9:50pm
