![]() | Home > Technical > Strange issue need help with!! |
V88ABA Member Since: 01 May 2012 Location: northampton Posts: 338 ![]() ![]() |
I can't help you at all I'm afraid but where did you get it done? Have always thought about doing this once warrantee runs out. What is the approx cost/savings/mpg/performance like!? Thanks |
garyc Member Since: 23 Feb 2012 Location: UK Posts: 33 ![]() ![]() |
I live in Northern Ireland and got it done over here. Cost 1500 and gives just slightly less mpg than petrol but only costs 74.9 per litre. Haven't noticed any performance difference but the system fitted will also inject petrol at high load to help maintain performance. |
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 ![]() ![]() ![]() |
There are loads of horror story's on this forum about fitting LPG to the supercharge engine. I think the 4.4 engine is ok but not sure. I wish you luck with yours garyc. These vehicles are not cheap to run. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
I would be very wary about anyone splicing into the CANBUS system on the car. Could end up causing nothing but grief further down the line |
DC_Supercharged Member Since: 14 Aug 2013 Location: Warwickshire Posts: 27 ![]() ![]() ![]() |
Try changing the LED's for CAN safe versions - they are a bit more pricey but may sort this issue for you..
