Home > General > Wet floor on the passenger side
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
I have been having wet floor on the passenger side.
I heard there was a draining tube from the A/C that tends to split. I wanted to tackle it today but could not find it.
Any tips?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  91 BMW 850CSI
Post #373601 Fri Feb 15 2013 5:56pm
grass cutter
Maybe the girls like your car just a little too much Rolling with laughter
Post #373782 Sun Feb 17 2013 8:42pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
The tube will be on the bulkhead side of the HVAC unit. This is the one that usually leaves a puddle under the car in summer.
I'm not sure on its exact location on the RRS but I imagine it won't be easy to get to. Prbably towards the middle of the passenger side of the bulkhead. Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #373896 Mon Feb 18 2013 6:34pm
Fatandre
Sorry, I am not following.
HVAC unit?
Bulkhead?
Yes, I am a noob Razz 91 BMW 850CSI
Post #373897 Mon Feb 18 2013 6:36pm
kav1187
Sorry i was working when i wrote that so wasn't very clear.
The HVAC is the air con unit you've taken a picture of. The bulkhead is the wall at the front of the cabin between you and the engine. So...the rubber hose is probably at the front of that air con unit (that also houses the blower fan). It should be near the bottom and should poke through the wall.
Just out of interest, does your car have a sunroof? Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
Post #373935 Tue Feb 19 2013 12:28am
