Home > Technical > DYNAMIC ANTI-ROLL BAR LEAK |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
I would contact Land Rover Park Royal, one of the forum sponsor.... Range Rover Vogue ‘17 TDV6
Wed Nov 10 2010 11:01am |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
Its an anti roll bar filled with power steering fluid, its allows for the movement of the suspension into off road and access height along with adapting to the road conditions when your driving.
Wed Nov 10 2010 11:23am |
Sizzle TDV8 Member Since: 22 Mar 2010 Location: London Posts: 117 |
Lee check a previous post of mine regarding this.
Thu Nov 11 2010 12:11am |
leescales Member Since: 10 Nov 2010 Location: ESSEX Posts: 2 |
Sizzle - hi mate - cant PM not enough posts..
Thu Nov 11 2010 1:54pm |
Last year a message was issued - "Stabilizer bar fluid weep - Dynamic Response vehicles".
Thu Nov 11 2010 10:05pm |
Lee if you look at my profile and check my posts you will find it.
Fri Nov 12 2010 10:51am |
RRSJS Member Since: 11 Feb 2013 Location: London Posts: 1 |
I have just received the same treatment from Hainault Stratstone service.
Mon Feb 11 2013 4:21pm |
Seems we have two similar threads running on leaking ARC bars http://www.rrsport.co.uk/forum/topic29840.html
Thu Feb 14 2013 5:49pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8852 |
I had the rear bar replaced on my Sport last year. Luckily it was covered by the warranty. The paperwork showed about £800 for the part and about 3.5hours for labour. VAT on top of that no doubt.
Thu Feb 14 2013 7:34pm |
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 |
To have the rear bar replaced you don't have to take the body off. It can be done in the way that they "open" your car from behind like a"can of tuna" just to get about 10cm space so that they can replace it. But it is true that on some LR services they don't know how to do that and they prefer to take the body off (and charge you a lot of££££)and some others like in LR Aichlseder Klagenfurt (Austria) they know exactly how to do it in 3h. 2008 RRS TDV8 HSE, Java black, Alpaca,..... |
Fri Feb 15 2013 5:29pm |
I just kept filling it up for a few months and the problem just went away |
Fri Feb 15 2013 5:50pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4344 |
This is correct. The rear bumper comes off, and the rear body mount bolts are removed. The body is then raised just enough to get the ARC actuator out |
Sat Feb 16 2013 9:00am |
Hi Mikey I just saw yours How to do it compilation 2008 RRS TDV8 HSE, Java black, Alpaca,..... |
Sat Feb 16 2013 9:38am |
Its taken a while to compile it, but hopefully it will be of use to a few people
Sat Feb 16 2013 9:53am |
