Home > Maintenance & Modifications > dpf filters
mse wrote:
it helps save the planet
No, it might help to protect a certain climatic state of the planet that some humans, currently, think is perfect.
The planet doesn't care what we do - life has survived changes that make AGW look like a fart in a hurricane. Indeed, the climate will change irrespective of what we do and life will carry on regardless.
Governments, however, find it the perfect excuse to tax the crap out of us. It's a scam and too many of the chattering classes have fallen for it hook, line and sinker. 2012 SDV6 - it's missing a couple of cylinders
Post #373411 Wed Feb 13 2013 10:21pm
Its called evolution.
Post #373413 Wed Feb 13 2013 10:31pm
mse
Lets not get on to climate change because i think you may have an appreciation of my view exactly opposite to my actual view Laughing
I know loads of farmers who do short hops without the DFP coming on...i wonder if the correct oil is being used, as mentioned that is one key reason why you might get the message.
Apparently how the dpf works means the regen drive is less harmful than the drives to fill it. Mike
2014 Facelift Discovery
Post #373431 Thu Feb 14 2013 12:13am
So do farmers use different oil to us? Mine is using whatever they put in at the factory, so i can't see that being the wrong oil. Shocked My dpf light came on at around 6500 miles on the clock of which only about 2500 are motorway miles, id be surprised if farmers do 2500 miles in a year in their 4x4's, they are usually in their tractors.
Post #373446 Thu Feb 14 2013 8:45am
mse
in my 11MY i did a month of 5 mile journeys in it every day...no DPF light on. Mike
Post #373507 Thu Feb 14 2013 5:26pm
drdelrrs
- mse perhaps you'll explain to me why a change in engine oil will change to build up of soot in the DPF which is from burnt fuel?
Post #373512 Thu Feb 14 2013 5:51pm
mse
Read the post above from oldcro he explains it. Thumbs Up he actually mentioned it
It is true (read your manual) - part of the reason for using the correct spec oil is about SAPs and the impact of the DPF.
Its common (because the correct spec isnt commonly available) to use the wrong oil...in fact is the difference between A and B
Incidentally - i assume you know how a DPF works - i though you were mechanically minded Question
Because i appreciate the sarcastic reply ive just made a little more thought through: Ash deposit increases exhaust back pressure, which increase fuel consumption & loss of engine power & deposit shortens the life of a dpf. It comes mainly from engine oil which is why low ash oil must be used! Gone are the day's of one size fit's all & viscosity is not a specification! Mike
Post #373513 Thu Feb 14 2013 5:57pm
mse
this may also help:
http://www.forddoctorsdts.com/articles/article-07-03.php
and
http://pmmonline.co.uk/technical/how-can-i...pf-failure Mike
Post #373514 Thu Feb 14 2013 6:04pm
Tbh, i think it would take more than a months worth of 5 mile journeys to bring the light on, doesn't it clean itself out every 2-3000 miles ? I know when mine came on i hadn't been on a long run for quite a while.
Post #373554 Fri Feb 15 2013 8:40am
drdelrrs
Ref the articles. quoted above ..
and
http://pmmonline.co.uk/technical/how-can-i...pf-failure "
Unlike the USA in the UK fuel and LR specified oils have complied for years. Unless an RRS owner replaced a recommended fuel or oil for non-synthetic or a cheap product then the engine oil will not alter the DPF's life.
Post #373586 Fri Feb 15 2013 4:20pm
mse
and
I think you are missing the point - the OIL spec did change in 11 and you struggle to buy it, but you can buy one that is almost identical but the long code has a B at the end - Land Rover put the correct spec in, i hope the dealers do (although i know of one that doesnt) but any other garage or top up...probably doesnt Mike
Post #373603 Fri Feb 15 2013 6:01pm
oldcro
Scotland
If your Range Rover has a DPF fitted your handbook recommends the following engine oil;
SAE-5W-30 with the spec WSS-M2C934-B.
Google the spec for info on different makes and suppliers, or confirm the correct oil will be used before any service is carried out.
The choice is yours.
Post #373622 Fri Feb 15 2013 7:50pm
oldcro
Scotland
Double post again. Big Cry
Post #373623 Fri Feb 15 2013 7:50pm
