![]() | Home > Technical > RRS SC Dynamic Response System |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
would it not have been easier to repair or replace ? 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9068 ![]() ![]() ![]() |
You will need to replace both dynamic anti roll bars with standard bars. A new bar, in the UK, costs £800 plus fitting. I really can't see the benefit of changing the whole spec of the suspension rather than just replace one component. 2012 SDV6 - it's missing a couple of cylinders
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4475 ![]() ![]() ![]() |
I wonder if it is as simple as disabling the ARC system in the CCF |
razirafi Member Since: 09 Feb 2013 Location: Philippines Posts: 3 ![]() |
Yes it would be easier to replace but the owner decided to have it removed as this component seems to have a high failure rate and this vehicle will also not be used off-road. Essentially what we plan to do is to trick the system into thinking that this component is still present if it can see the voltage readings from the pressure sensor. But I still need to know what other inputs it looks for. Does anyone have a pdf file of this DR system and willing to share it with me? |
Just to point out the the dynamic system is more for on road than off road...personally i cant see why you would want to remove it - its a great system.
Yes you are correct, the DR is more suitable for on-road maneuvers and yes it is a great system except that it leaks in so short a time and gives off clunking sounds (not very great it seems). Anyway, thanks for your reply and insights guys...I think I will have to go about this on my own. |
If the system is working - then it shouldnt do the things described though...good luck Mike
from my understanding, they are just going to remove the part, without replacing it, or anything else, trick the ECU, and then drive |
