![]() | Home > Maintenance & Modifications > Air compressor running too long |
yes, change the relay is one of the first. I now add it into the yearly schedule so I dont have to worry about it. It's less than a tenner and takes 2 minutes. Bodsys Brake Bible
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
Does changing the relay help with any other issues e.g. sagging suspension or a slow lift when asking for off road height? 2012 SDV6 - it's missing a couple of cylinders
It'll only help sagging suspension if the relay comes with 50m or 3T steel wire to brace it alll up.... |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Thanks Bodsy, upon further inspection it is shutting off, I have a relay coming so will change it anyway. I think the problem is that the compressor is noisier that it used to be, what would that indicate and should I do anything at this stage. Many thanks.. |
Thanks Bodsy - I guess that question deserved a slightly |
Rrs |
Yes I was lucky to be able to buy the number plate many years ago before the values went really high!
