Home > Maintenance & Modifications > Engine oil 2.7 TDV6
GAZB
Engine oil 2.7 TDV6
I know there are lots of posts regarding engine oil and I see that alot of people recommend using Castrol Magnatec , is there any better oil to use , I currently have left over about 15 litres of Exol Vimax 0w 30 fully synthetic oil that I use to use on my Honda Accord 2.2 CDTI , its ACEA B3 , my RRS has done 111k would this be okay to use ?
Post #372507 Thu Feb 07 2013 10:22am
Bodsy
Site Sponsor
normal spec is 5w30.
Dont know what the impact of 0w30 wouild be, probably nothing, but you need an oil/engine developer to give you more insight... Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #372508 Thu Feb 07 2013 10:27am
I'd personally not use 0w when the manual says use 5w, but that's just me.
The car needs 5w, so for the sake of £18 are you going to risk your 7k engine? RRS gone
Post #372510 Thu Feb 07 2013 10:40am
Like awd, I'd be disinclined to deviate from the recommended oil if it were my car. Smile ON THE WAY: BMW F21 M140i
Post #372511 Thu Feb 07 2013 10:58am
CUCO
Spain
check this:
http://www.discotr.es/viewtopic.php?p=104675#p104675
there is a list of approved oils for our engines.
Post #372527 Thu Feb 07 2013 12:16pm
^^^ and not an 0w in sight there Whistle ON THE WAY: BMW F21 M140i
Post #372530 Thu Feb 07 2013 12:22pm
GAZB
Your right mate ill just put the 5w 30 in , only asked about the 0w 30 because I had seen on some other sites about people using 0w 40 Mobil 1 in there TDV6 engines
Post #372542 Thu Feb 07 2013 12:53pm
GAZB
How do I tell if my 2005 RRS is DPF or non DPF
Post #372543 Thu Feb 07 2013 12:57pm
Your motor hasn't got a DPF they were only fitted to late 2010 models onwards. Wink
Post #372545 Thu Feb 07 2013 1:04pm
GAZB
Thanks Ady
Post #372546 Thu Feb 07 2013 1:07pm
CUCO
Spain
to see if our car have DPF, just look under the car:
with DPF:
http://www.discotr.es/download/file.php?id...h43_04.png
without DPF:
http://www.discotr.es/download/file.php?id...h45_39.png
Post #372575 Thu Feb 07 2013 3:21pm
GAZB
In the end I bought 10 litres of Fuchs Titan XTR Synthetic 5W 30 oil , got a good deal £36 including delivery , did a fair bit of research and Fuchs lubricants are well recommended.
Post #374094 Wed Feb 20 2013 11:38am
GAZB
Post #374095 Wed Feb 20 2013 11:38am
