| RRSPORT.CO.UK | ||
|  | Home > General > Bought a TDV8 Today! |
| 57TDV8 Member Since: 16 Jan 2013 Location: Cirencester Posts: 113    | Good advice.  Romans have agreed to let Guava in Guildford fix it as their price was very reasonable at £555 inc. VAT (£200 alternators + 2.6hrs labour).  By the time Romans had collected it & done the work, wasn't worth it so they'll pay Guava direct.  I also get a free 30 point check which will be interesting...  | ||
|  Wed Jan 23 2013 5:24pm |
| RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280      |
 Even better  TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten | ||
|  Wed Jan 23 2013 8:56pm |
 Mentioned this to head of service at Guava today and he said only way to do this is with the battery out as even when off the RRS 'wakes' every 45mins and will adjust suspension accordingly...? | ||
|  Wed Jan 23 2013 10:00pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      |
 It is true that the vehicle wakes up at fixed intervals and 'self levels' but if it is parked on a level surface then there isn't any levelling to do so no air should be used from the reservoir. If however there is an air leak in the suspension such that one corner or end drops then the car will attempt to self level until the air pressure in the reservoir is exhausted and the car ends up right down on the bump stops. This is what was happening to my RRS which meant when I started it up first the rear pumped itself up and then the front - so a bit of a free fairground ride effect  .  I collected it from my LR Indie yesterday and they have fixed the leaks from the air compressor and the rear transfer valve by replacing both components. Pleased to see that this morning it is still sitting level at on-road height so they appear to have done a good job. Bit expensive at about £900 but at least I now have the new and apparently superior AMK compressor and software package. The high cost is mostly down to labour since it is time consuming to track down all the leaks. The compressor costs about £360 and the valve about £80. I trust my Indie to do a good job. They even told me they always insist on ordering a fresh compressor and not one from their supplier's stock since apparently they have a shelf life (something to do with the silica gel drying crystals in the drier perhaps?) If you leave the car parked up but lock it in 'access height' first then apparently it does not attempt to self level so you should do this if intending to leave it parked for extended periods or when travelling by ferry. I'm a bit unsure of this next bit but have read that if you leave the car parked on an uneven surface - like with one wheel in a big hole then the car attempts to self level but can't and so will exhaust the reservoir and end up drooping - which is what your guy at Guava may have been talking about. Sorry about the long epistle but perhaps this might help you. 2008 MY Java Black TDV8 HSE   | ||
|  Thu Jan 24 2013 12:39pm |
| 57TDV8 Member Since: 16 Jan 2013 Location: Cirencester Posts: 113    | Fair enough, good explanation of what could happen.
|  Thu Jan 24 2013 2:33pm |
 Good news on the LR inspection, sounds as if you have a good one. See this recent thread about front bushes etc. http://www.rrsport.co.uk/forum/topic29559.html. 2008 MY Java Black TDV8 HSE   | ||
|  Thu Jan 24 2013 4:50pm |
| 57TDV8 Member Since: 16 Jan 2013 Location: Cirencester Posts: 113    | Cheers Paddi, picked it up this afternoon   | ||
|  Fri Jan 25 2013 4:04pm |
| Shiny Silver Member Since: 16 Feb 2012 Location: Cambs Posts: 70      | 57TDV8... any update...
|  Thu Jan 31 2013 8:32pm |
 Booked in at Guava, will be at my cost, but will discuss with Romans, but guaranteed a decent job/re-alignment of the wheels etc. as it's got new rubber. Can't fault Guava, their head of service will pick it up from my house as it's sort of on his way & deliver it back   | ||
|  Fri Feb 01 2013 9:37am |
| stuttgartsfinest Member Since: 19 Nov 2012 Location: Herts Posts: 21    | Looks great!  Hope you sorted the battery issue.
|  Fri Feb 01 2013 10:38am |
|  Fri Feb 01 2013 1:14pm |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355    | might be a failing compressor
|  Fri Feb 01 2013 2:53pm |
 Looks that way, the light was yellow. Now cancelled Guava & dropping it off at Romans on Tues for pick-up Weds for both hydro bushes, drivers door & compressor, let's see... | ||
|  Fri Feb 01 2013 2:57pm |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563      | Don't despair these are all common failures. Driver's door probably requires a new latch which is an easy job. The suspension issue could be a blockage in the drier which can be fixed without fitting a new compressor. Think I would want to know who was going to do this work since the air side of suspension requires a bit of experience and the right diagnostics kit. Would be interesting if Romans could be persuaded to tell you. Good luck and please keep this thread updated. 2008 MY Java Black TDV8 HSE
|  Fri Feb 01 2013 4:03pm |
| Posting Rules
 Just got back from a trip out, a few stop start short hops & had the suspension error, i.e. fixed at normal height.  Eventually went away but just sat on the drive going up & down (engine running) and got just a text warning (no red light) saying Suspension raising slowly and it was the front that was slow to raise, back OK!
