![]() | Home > Technical > Got it at last..... |
Gerico Member Since: 02 Jul 2011 Location: Essex Posts: 224 ![]() ![]() ![]() |
Make sure the battery connections are good and tight. A good old fashioned charge may be in order if it has been sitting round for a while.
SturgeRRS Member Since: 05 Jan 2013 Location: Surrey Posts: 96 ![]() ![]() ![]() |
Many thanks Richard for the advice. It has been sitting around at the dealers for a couple of weeks since I brought it so that may be the case. That said thought a 70 mile drive home would have done the trick.
Morpheus-RRS Member Since: 29 Oct 2012 Location: Lanarkshire Posts: 83 ![]() ![]() ![]() |
Congratulations on the new sport, I'm sure you'll enjoy it as much as ive been enjoying mine... |
Hi Dave thanks, the trouble with that is, if your sitting around waiting for some one and you wanna watch the tele you have to have the engine running. Not very Eco friendly not to mention the cost...... |
Very True Lee, I think i'll maybe mention it to the dealer next week and see what they say. Dave.
Well It died big time today with all the lights coming on and the clock spinning around. AA man came out and jump started it and said "you can't have the ignition on without starting it,will drain the battery out in no time" He checked battery and Autonator and said its all ok. I'm not convinced though. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
Is the battery the correct one for the vehicle? As in, is it the correct LandRover battery? These vehicles have smart charging systems in them and it has been suggested hereabouts that they are sensitive about the battery itself.
The AA man is half right... just leaving the ignition in radio on mode can drain the battery.. but only after an hour or so..... certainly not 5 minutes RRS gone
