![]() | Home > Off Topic > building an extension advice |
| codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171
Does one no approve, Ady? The render ha since been whitewashed so part of it ties into the rest of the house(bungalow), if we had gone two storys up with the render instead of the cedar cladding it would have been too much.
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716
No problems, glads its been colour coded to match though |
I had to cover the brickwork with something,and I didn't fancy doing a "wet cast"
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Gone: a comprehensive list of imprezas and a Merc ML AMG |
This might be of some use Nick. http://www.ratedpeople.com/?gclid=CJrgrsjn-7QCFQzKtAodkSwAmQ Then again it might be a bit of a ball ache. |
my worry is the newer of the two extensions (classed as a hallway extension on the plans), I think this was done as single storey, just to match the other older one in size, just so the old owners could put up their conservatory
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
You need to do some proper investigation work. It involves doing some digging (to see what foundations were provided) and perhaps removing some plaster to see what lintel you have over the french door. Even if the lintel isn't up to the job of carrying another storey, it's not exactly major surgery to change it for one that will work when the extension is being built up.
| Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657
Not much vision is required for a garden room, an architect is overkill in my opinion as a decent builder should have a portfolio of previous jobs. Also, a lot of builders offer the full package from plans to sign off.
| All times are GMT |
