![]() | Home > General > back end wobble under acceleration whats wrong |
I'd get the alignment checked, just in case your two rears are facing different directions and its causing tension in the rear suspension under hard acceleration? RRS gone
Ice and a heavy right foot??
andyteesside Member Since: 20 Jan 2013 Location: teesside Posts: 2 ![]() ![]() |
no not ice and heavy foot..... back end wobbles bad to the point you come off accelerator as its almost uncontrollable.... i taking it to the garage tomorrow to get it checked but busted wondered if it was the norm or not??! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
Once you've checked the simple stuff as already mentioned then you're probably looking at a shot bush somewhere which is allowing one wheel to move when loaded under acceleration.
Saeedasghar Member Since: 11 Dec 2012 Location: Worcester Posts: 104 ![]() ![]() |
Could be something as basic as a bush, wheel bearing or rear tie rod end. Have you checked the wheel nuts just to be on the safe side incase one or two have worked they way loose at all. |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Was it always like this or has it just happened?
