Home > Maintenance & Modifications > after changing my bulbs to lead in the headlights got a mess
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
after changing my bulbs to lead in the headlights got a message.
What is it?
The yellow light with the light showing up.
Dont midn the brake light it is just one loose cable that will be fixed.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  91 BMW 850CSI
Post #369994 Fri Jan 18 2013 6:00pm
That is the adaptive headlights icon. Do you have adaptive lights fitted? (they move the beam left and right as you steer). If not, then I'm guessing that you might be seeing a canbus error caused by incompatible light fittings. Did you buy Canbus-friendly LED lights? 2012 SDV6 - it's missing a couple of cylinders
Post #369998 Fri Jan 18 2013 6:55pm
Fatandre
they were supposed to be canbus friendly 91 BMW 850CSI
Post #370001 Fri Jan 18 2013 7:06pm
Fatandre
those
http://www.ebay.co.uk/itm/130591243207?ssP...1439.l2649 91 BMW 850CSI
Post #370003 Fri Jan 18 2013 7:10pm
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Put your old bulbs back in and if error clears your led's aren't error free as advertised.
Nik 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #370005 Fri Jan 18 2013 7:24pm
Fatandre
Nik
Just did it and its all good now.
Man I have been ripped off!! 91 BMW 850CSI
Post #370008 Fri Jan 18 2013 7:56pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Fatandre wrote:
Nik
That's annoying. Where did you get them from? 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #370028 Fri Jan 18 2013 9:26pm
Fatandre
JasM wrote:
Fatandre wrote:
Nik
link is in this thread.
I got a answer on another forum that sounds like that.
Maybe i need to restart the lights. I will put the leds in again tomorrow and see how it goes.
Did you let the car go to sleep before removing the headlights? If not this too may trigger the AFS fault,if you didnt do this,let the car go to sleep,then unplug each headlight,plug back in and try again,if fault still shows up you may need to get the cars brain read for a fault description logged.
When i had the problem in my previous post,the fault logged was AFS motor issue,helped me realise my HID ballasts were stopping the movement!
Also did you move the eyeballs at all?again a plug and unplug might rest them!
HTH 91 BMW 850CSI
Post #370045 Fri Jan 18 2013 11:12pm
Fatandre wrote:
those
I fitted ones that look the same as those in my Sport recently. No errors so far. 2012 SDV6 - it's missing a couple of cylinders
Post #370118 Sat Jan 19 2013 3:02pm
Fatandre
I will fit them again and see what happens 91 BMW 850CSI
Post #370121 Sat Jan 19 2013 3:31pm
madmackie
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
take the bulbs out one by one and turn it round try that
Post #370150 Sat Jan 19 2013 7:27pm
Fatandre
New bulbs have been mouted and it is all good 91 BMW 850CSI
Post #371030 Sat Jan 26 2013 12:23pm
robmeister1969
United Kingdom 2005 Range Rover Sport Supercharged Santorini Black
Fatandre wrote:
JasM wrote:
Fatandre wrote:
Nik
HTH
Just curious about your 'HID ballasts were stopping the movement' comment. My AFS has not worked on my RRS SC, and I wondered is you had the same problem and managed to resolve it?
Post #392059 Sat Aug 17 2013 7:25pm
