Home > Maintenance & Modifications > My front and rear lights get foggy. How to tackle that?
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
Have you had this situation? 91 BMW 850CSI
Post #369975 Fri Jan 18 2013 4:41pm
Handbook will tell you it's 'normal'
I guess your location with extreme weather means you will be slightly more probe to it than others Confused ON THE WAY: BMW F21 M140i
Post #369978 Fri Jan 18 2013 4:53pm
Fatandre
Well. ok. If it is normal then its one less problem. 91 BMW 850CSI
Post #369995 Fri Jan 18 2013 6:45pm
It's normal. The light units have rubber breather pipes on the back so they should clear with use (heat from the headlight obviouslhy helps). 2012 SDV6 - it's missing a couple of cylinders
Post #369997 Fri Jan 18 2013 6:53pm
