![]() | Home > Maintenance & Modifications > changing a side light bulb |
P7tey Member Since: 03 Oct 2012 Location: Devon Posts: 144 ![]() ![]() ![]() |
Remove the grill, (there's a how to on here somewhere), then pull up the metal tabs either side of the headlamp unit, (until the holes line up), then pull the unit out forward, being careful not to scratch the bumper with bottom of the units!
Embo Member Since: 13 Nov 2012 Location: Newcastle/under/lyme Posts: 23 ![]() ![]() ![]() |
cheers |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
How to threads linked in my Sig... Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section |
^^^ link is in the 'how to' thread |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
its not a big job mate and should only take about 15 minutes to complete |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9061 ![]() ![]() ![]() |
Tip: use a loop of string to pull up the securing catches. Loop it under the hook and pull up. Much easier than using your fingertips |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
I wish I'd thought of that when I switched my bulbs for led's 2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
thanks guys |
