Home > Maintenance & Modifications > End of 3.5mm plug stuck in Aux socket, how to get it out?
Kensta
The tip of the plug is snapped and stuck down the inside of the Aux socket behind the drivers arm rest in the rear seated area , anybody know how to get it out or will it be easier just fitting a new socket if they are available ? Java black 2006
Post #365724 Fri Dec 07 2012 8:48am
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Suffering from the same problem myself. Big Cry
Did you manage to get it sorted? 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #369079 Fri Jan 11 2013 10:52pm
Kensta
U had Anyjoy sorting it? I've not attempted mine yet Java black 2006
Post #369146 Sat Jan 12 2013 11:03pm
JasM
No not yet. Sad 2014 L405 SDV8 RR Autobiography Cool
Post #370034 Fri Jan 18 2013 9:44pm
DrLex
Iceland
Does the panel look like this?
If so, you can remove it out (friction fit) by holding the hinged cover and pulling firmly as it it were a recalcitrant drawer.
Unplug the connectors and with better access, you may be able to extract the tip. Dab of superglue on the other end of the broken plug can be a last-ditch action- have done that with snapped keys.
If no joy, it's either around £30 for a new one or get a friend with a soldering iron to swap in a new socket on the board.
Post #370066 Sat Jan 19 2013 9:22am
mse
This was covered only a few weeks ago...have a look at the solution Mike
2014 Facelift Discovery
Post #370106 Sat Jan 19 2013 2:27pm
DrLex
Iceland
Here, since Mike CBA to post a link. Magnet was the missing suggestion!
Post #370114 Sat Jan 19 2013 2:48pm
mse
Yes but if i searched for everyone asking i may as well be the search engine Exclamation Rolling with laughter Mike
Post #370130 Sat Jan 19 2013 5:45pm
JasM
Thanks DrLex for the post. I will give it a try. Thumbs Up 2014 L405 SDV8 RR Autobiography Cool
Post #370154 Sat Jan 19 2013 7:32pm
