![]() | Home > In Car Electronics > Sat nav problem |
| Mitchmx Member Since: 22 Jul 2012 Location: Bristol Posts: 156
After some help.
LOL
It worked! |
| Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268
I had the same problem when i bought a genuine disc to update mine to 2012.... Defaulted to europe map |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
The disc only has the maps not the firmware that gives you the display Mike 2014 Facelift Discovery |
How do I update that? Is it a job for bodsey? |
You might be able to do a slight upgrade but you wouldnt be able to go too far...i cant recall the MY range you can go to sorry Mike
It changed at 2010 model change I think.
| mlines Member Since: 10 Dec 2006 Location: UK Posts: 480
As far as I am aware you cannot upgrade to the latest "look and feel" SatNav as its a completely different system from a different manufacturer.
You cant go to the new 12MY on system or the HDD navigation system thats on the 10 or 11 on or actually from 10/11 to 12/13 Mike 2014 Facelift Discovery |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Glad I read this thread - gave me the courage to try my 'bargain' disc which (once I had changed the country to UK from the default Belgium) seems to work perfectly well so far. |
| sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690
Just been reading this pst as have similar fault. I had to change rom Belgium to UK but ave to do ths every time the sat av sarts up. Did you experience this problem? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx 20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control |
No; I only had to change from default Belgium to UK once at the 'destination' screen as described by Bodsy above and my £10 fleabay bargain disc appears working just fine. 2008 MY Java Black TDV8 HSE
Ok thanks for clarifying TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
| All times are GMT |
