![]() | Home > Faults & Fixes > Water drip from interior light panel ?? |
| Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268
After some hard conerning and braking, i have noticed a drip of water from the front of the interior light panel above the centre console !
LMAO !! hey no probs... |
| kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307
Monty - this screams sunroof drainage issue, but it could also be water getting in around the GPS aerial? Is it loose? Has it been sprayed with a pressure washer?
Ive had another quick look and cannot see any blockages in the sunroof by pouring water into the channels..
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
Sounds very much like sunroof drain pipes...the best bet is not to pour water down them, its likely to not work - you need to fire some compressed air down up (probably) or down them
Wilmtake a look once the rain has stopped here tomorrow and report back! Why?.. Because i can....
| Cupra Member Since: 20 Oct 2012 Location: Kent Posts: 81
mine did the same Monty, fired up the Audi compressor and blew the pipes through. Since then ive had no more leaks |
Rather than a compressor, some of that 'netting curtain' wire is excellent for gently pushing down the drain tubes to clear them out. Bodsys Brake Bible
Don't forget there are drain tubes that go to the rear of the car also. Be careful pushing wire or using high pressure as there is a 90° elbow in the tubes in the A pillars which could cause leaks in other places if its pulled off.
Had the front grilles out and only found a very small amount of muck, water flow was same before and after.
Have a read of the whole thread I linked above...tells you everything you need to know. |
