| RRSPORT.CO.UK | ||
|  | Home > In Car Electronics > 7 pin and 13 pin dual wiring possible? |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355    |
 Can a car be dual wired to have an old fashioned 7 pin alongside the new 13 pin electrics?
|  Fri Dec 28 2012 11:56am |
| WolfgangK Member Since: 28 Dec 2011 Location: Heilbronn Posts: 86      | May be, you find something here
|  Fri Dec 28 2012 11:10pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | The only way you could dual wire is to tap in to whichever you fit and run a second set.
|  Sat Dec 29 2012 4:18pm |
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716    | I use a twin to 13 adapter for my new van, easier than purchasing another set of highly priced LR electrics and I don't need to worry about the bike rack too | ||
|  Sat Dec 29 2012 4:22pm |
| Gooser Member Since: 28 Dec 2012 Location: Warrington Posts: 7      | I have a 7pin to 13 pin conversion lead, cost £25 from Towsure | ||
|  Sat Dec 29 2012 5:25pm |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355    | Cheers for the replies   | ||
|  Sun Dec 30 2012 12:11pm |
| CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59    | as long as you dont connect two plugs at same time (no usual) you are ok if you "double" the electric installation, that is, double wire from the car to the 7 an to the 13 pin socket.
|  Sun Dec 30 2012 12:32pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | 13 Pin has an additional feed i thought - so i could believe something wouldn't work going from the Black/White 7 to 13 pin via an adaptor.
|  Sun Dec 30 2012 12:44pm |
| CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59    | 13 pin pinout:
|  Sun Dec 30 2012 1:07pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | It depends which model you have
|  Sun Dec 30 2012 1:34pm |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355    | cheers again.
|  Wed Jan 02 2013 8:32am |
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716    | My adapter works with my alko ATC, Everytime I plug it in the system can be heard and the light goes a solid green
|  Wed Jan 02 2013 12:11pm |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355    | That's very interesting Nick.
|  Wed Jan 02 2013 12:13pm |
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716    | Yes, I have twin on the car, and the adapter plugs straight in to the caravans 13 and the ATC activates
|  Wed Jan 02 2013 12:19pm |
| Posting Rules
