![]() | Home > Technical > Noise when slowing down |
Possibly front diff related. Fairly common issue, unfortunately...
| Jonesyscoob Member Since: 21 Oct 2012 Location: Birmingham Posts: 95
Thanks is there any way of diagnosing which one? If its front diff what needs to be replaced? |
Jack up the front end, and check for any play in the wheel bearings, or any noise as you turn the wheel.
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
If you lift off from about 60 or more e.g when coming off on a motorway junction, does it make a fairly loud 'wup, wup, wup.... noise a bit like the noise a flat tyre makes? Mine did that when the diff was on the way out. +1 for DM's comments about black silvery diff fluid and also lots of metal particles adhering to the magnetic drain plug.
