![]() | Home > Wheels & Tyres > RELATION BETWEEN WHEEL SIZE AND PERFORMANCE!!! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9115 ![]() ![]() ![]() |
The 19 inch tyre has a slightly smaller overall diameter (about 2.7% or 20mm). This gives the following:
Phew! Excellent write! |
kml4ever Member Since: 24 Dec 2011 Location: İstanbul Posts: 35 ![]() ![]() ![]() |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 ![]() ![]() |
I'm not ashamed to admit, I have no idea what half of that actually means but love the fact that someone asks a question on here and someone else actually takes the time to explain in such detail when they could quite easily just skip to the next thread. I can honestly say this is one of the best forums I've used |
While RRSTDV8's science is OK and right in theory its only is partially correct because the airflow under a 'Sport' is pretty messy given the airflow separators under the front apron in front of the wheels so the change in frontal area is not likely to make a significant change and the theory also asssume the air is still whereas the wind will probably be different on different days, as is wet/dry road and air temp. (so engine efficiency)!!.
@drdelrrs Hence my last line - the difference between tyres is small but measurable - if you can be bothered to do it. |
imo its not psycological and its not abt the weather because i just changed the 22 to 19 and then next day started to feel the difference weather difference was may be 1 or 2 degrees and olso the wind etc.Because of the smaller wheels i think the acceleraiton is better and on the other hand if i use 275 40 20 s the difference is higher like 4% they are smaller then the 22s.so imo if i go for 20s may be the acceleration will be better and olso the feeling because with 22s its always a little bit shaking the steering wheel... anyway thanks for all giving really valuable information |
A smaller overall diameter tyre will give better acceleration because you shorten the gearing. But the effect won't be huge.
RRSTDV8 thanks alot really helped me too much |
KaminskaJacekstreic Member Since: 25 Apr 2012 Location: Sunbury Posts: 228 ![]() ![]() ![]() |
With 19's car using less petrol and is quicker Big fun of RRS-my one WHITE-RED with wide body kit plus RS alloys all from KAHN |
