![]() | Home > General > Current fuel economy in the cold weather ? |
| range17 Member Since: 08 Oct 2012 Location: bedford Posts: 109
Thanks for info bmw gs1200 adventure defender 90 off roader |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
Dont really have a set garage, so dont think it would be this[/quote] In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
| V88ABA Member Since: 01 May 2012 Location: northampton Posts: 338
I average 18mpg in my 2007 s/c. Thats no motorway driving. |
| Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268
Changed airflow sensor.and air filter, been running around now fo 300 miles town only driving.. no different to my normal pattern.and i am now achieving
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
To be honest, I'd doubt that mud flaps make any real difference to fuel economy. I know they look like barn doors hung out in the slipstream but the reality is that they're sat in just about the most turbulent airflow around the car. The wheels make such a mess of the air that immediately behind them the airflow won't care that it's hitting the mud flaps.
| Saeedasghar Member Since: 11 Dec 2012 Location: Worcester Posts: 104
I have a tdv6 2.7d I get around 21mpg all city driving local short trips. I have been considering using 2 stroke fuel additive to help with mpg and to help lubricate internal bits after many hours on forums reading up on the matter. |
Diesel is a lubricant. Anywhere the 2 stroke oil will go has already got diesel going there already. |
| npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716
Diesel was more lubricated till it went low sulphur, hey say adding 2so will help, I'm not convinced |
| jolleymike Member Since: 22 Aug 2008 Location: Wigan Posts: 55
ive found no difference in MPG, did a long run manchester to aylesbury this week averaged 26mpg on the motorway reset the counter when i filled up and after town diving it is averaging 22mpg, not bothered really though cos the 59 plate Focus RS we had struggled to get above 22mpg in any type of driving. Discovery TD5 commercial (gone)
To be completely honest the thought of added mpg is just a bonus if it happens. It has been suggested that if you do add 2 stoke it can possibly increase mpg by 5% (for some one who drives a rrs fuel efficiency would never be a major factor when buying it else you would not own one lol ).
How does 2 stroke oil help the EGR valves? The only way it can lubricate them is if it goes through the combustion chamber without being burnt. If you're putting unburnt oil through the exhaust system then you're going to quickly kill a couple of catalytic converters. Which is more expensive - EGR or cat?
| Mike_S Member Since: 03 Dec 2012 Location: Dunstable Posts: 15
'06 S/C
| calgary_RRS Member Since: 12 Jan 2013 Location: Calgary, AB Posts: 2
I have an '10 RRS 5.0. I drive regularly to Edmonton on the highway about 300km north. In the summer (about 20-25 deg C) I've gotten between 13-16L/100km usually depending on my right foot (15-18 MPG). Winter driving this year (20-25 deg C below zero) has reduced that by about 10%. I don't know why the cold weather changes things but the results are pretty consistent. I was expecting a slight improvement as there is no speed increases for straightaways and such in winter, but that doesn't seem to be the case. |
| Tony666 Member Since: 27 Jul 2011 Location: Barry Posts: 170
I'm still dubious about the reason for increased fuel consumption during winter. Over the last few months I've lost about 2mpg. (from 28 to 26mpg). I understand that the fuel burning heater uses fuel, but over the last few months when I've started my car it's usually above 4c, which I believe is the temp it operates below. I also very rarely use heated seats or screens. The only thing I use more is the headlights, could they really be the reason for the drop in mpg? |
