![]() | Home > General > More problems |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
Welcome to the world of British-built cars. |
sorry to hear your having so many problems Neil.
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Garage won't help
Is this a new car to you?
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4505 ![]() ![]() ![]() |
Yes, 36mm and opposite thread. |
Yes 36 mm it was just stuck fast
If the Ecu detects a massive drain such as a shorted out alternator, it will shut down. Not uncommon. Need to be a bit more aggressive with it. Special tool No 7, also known as large hammer, and not your claw hammer from kitchen cupboard! 2x TDV6. SE and HSE. Both returned to sender with issues👀
Blow lamp and big copper hammer got the fan off
Can't remember on V6 if there is front pulley sensor. Have a good look round areas you worked in to make sure all is plugged as should be. |
Tamworth is just a bit too far, just seen your avatar |
Yes key was in my pocket next to car or with in less than 10 feet all day
If it locks and unlocks the car on normal key should still be sync'd. Not up to speed on keyless go systems but know its possible to confuse any key when reconnecting battery if in ignition 2x TDV6. SE and HSE. Both returned to sender with issues👀
It's only a 2005 so not keyless |
As soon as it starts and faults cleared its going
