![]() | Home > In Car Electronics > Rear demister / defroster |
| kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307
No worries - hope you get it sorted |
| Stefan.lajszczuk Member Since: 10 Oct 2012 Location: West Yorkshire Posts: 70
Sorry for the delay but I only got chance to look at this issue yesterday.
Good stuff! I'm glad you got it sorted.
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
Finally got around to looking at the demister on my RRS today.
Please don't use choc blocks! They should be banned |
I'd much prefer to use a LR connector if one can be ordered. As you say, spade connectors in some form of protection would be a reasonable alternative.
I reckon this would do the job perfectly:
That's the same connector isn't it? That site is brilliant...will be useful for my vw golf project |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Well .... after a long delay mostly caused by illness I finally had an opportunity to look at my rear demister. Following the procedures posted by Kav and others it was clear the corroded connection was my problem too. Cleaned up the female side by rolling up a small rectangle of 240 grit wet and dry paper into a tiny tube with the abrasive side outward and then reversed the process to make a tiny tube with the abrasive side inward to clean up the male side. Pushed the connector back together and then tested the screen by starting up the engine and hitting the switch. Couldn't seem to detect voltage across the heating elements but I was a bit worried about damaging them with the sharp probes on the multimeter. It was actually simpler to just 'huff' on the screen and after a few minutes off heating this worked really well and it was possible to see if every element was working by the pattern of condensation clearing over the elements individually. Luckily they all seemed to be working fine.
Great news! Another win for the DIY brigade |
| Rangster Member Since: 22 Nov 2012 Location: Stoke on Trent Posts: 30
I took mine into Stratstone for an issue with the HRW and they told me it wasn't working and that it wasn't covered by the warranty (??).
Should this thread be under the "Faults and Fixes" section?? RRS TDV8 MY2010 Stornoway Grey Full Exterior Autobiography Factory Upgrade Piano Black Interior Trim inc Steering Wheel Ivory Premium Perforated Leather 22" 5 spoke "Style 7" Diamond Turned Alloys Towing Pack Diesel Tuning Box Privacy Glass Side Steps Best vehicle I've ever driven. Current garage also includes; Mercedes 320 CDI CLS TVR Tuscan S |
Just an update;
| Finn mc Missile Member Since: 13 May 2016 Location: Home Posts: 16
Hi, love this forum.
| All times are GMT |
