Home > General > Steering round right hand corners |
1st port of call would be to check the alignment RRS gone
Tue Dec 18 2012 9:42pm |
Lovey Member Since: 22 Nov 2012 Location: East Sussex Posts: 12 |
Tue Dec 18 2012 9:46pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Specialist job, check www.alignmycar.co.uk to find a local specialist with the right equipment ON THE WAY: BMW F21 M140i
Tue Dec 18 2012 9:51pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4346 |
1st post of call should be tyre pressures |
Tue Dec 18 2012 9:52pm |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 |
Garage.
2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
Also check your nuts
Tue Dec 18 2012 10:02pm |
Hi Ady
Tue Dec 18 2012 10:33pm |
Next step i'd get it to a garage and get all steering joints checked aswel as wheel bearings.Just out of intrest what wheels have you got on your motor? |
Tue Dec 18 2012 10:39pm |
Ady
Tue Dec 18 2012 10:46pm |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
Probably an ARB issue. Does yours have dynamic stability control?
Tue Dec 18 2012 11:10pm |
rogerpop Member Since: 14 Jul 2012 Location: blackpool, Lancashire Posts: 14 |
Could be wheel bearing. Just done mine. Fairly easy job. |
Wed Dec 19 2012 8:34am |
Mitchmx Member Since: 22 Jul 2012 Location: Bristol Posts: 156 |
I had the same problem a few months ago. It's been fine since and not done it.
Wed Dec 19 2012 9:19am |
Sorry somehow missed the bit where it says it was grinding. Transmission or CV joint would be my guess. Try putting the steering on full lock left/right and drive forward slowly. Get someone to listen to the wheels to see if there is a clicking sound as you go round. If it clicks then it's probably a CV joint. |
Wed Dec 19 2012 9:50am |
Rangster Member Since: 22 Nov 2012 Location: Stoke on Trent Posts: 30 |
Sounds like the DSC (Dynamic Stability Control). I've had the same issue on right hand corners at anything more than slow speed.
Thu Dec 20 2012 6:44pm |
