![]() | Home > General > Heat coming from rear wheel |
| npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716
Could be handbrake or bearing? |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
Same as above although I had off side rear caliper sticking. Worked the pistons back and forth and fitted new discs and pads and been fine ever since. 2x TDV6. SE and HSE. Both returned to sender with issues👀
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Experienced mechanics generally say if the wheel is hot then its a brake problem. If the wheel is not hot then suspect something else.
Nothing wrong with owning a Jeep. I had a Cherokee for 14 years. Seems to be common issue, mine had several front calipers replaced in its lifetime. Only got rid of it when it needed a radiator, cat and exhaust and battery in one sitting. Apart from ghat it only got serviced once a year Tyres and ball joints and a manifold gasket. Not bad for 14 years and 106k miles. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Nik,
| Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657
Thanks for the replies. I was out in the car last night for an hours drive and returned with no issues so its an intermittent problem.
Popped into my local specialist and he thinks its probably a sticking caliper, just so happens he had two other sports in with the same problem. Rang a stealer to see if it was covered under warranty which was a probably yes but what interested me was that they told me I don't have to use a main dealer for warranty work, any vat registered garage will do, something I didn't realise was the case.
Yes - I think it is an EU regulation called the Motor Vehicle Block Exemption. Basically disbars Manufacturers from excluding independents from warranty work.
Thanks.
2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
It is a mechanical failure but warranty company may say it is fair wear and tear. Personally I would have thought that on a MY 2008 vehicle you could reasonably expect the caliper not to have failed. Good luck 2008 MY Java Black TDV8 HSE
That will be my line of attack, late 2008 car with 32k miles i dont expect to replace calipers, especially as the LR extended warranty has just cost me over a grand 2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
| spud1234 Member Since: 28 Sep 2012 Location: Co Durham Posts: 83
Nik, I have used that same 4x4 garage on Portrack for everything but as you say any VAT registered garage can do it. They will tell you if it is covered if you show them the warranty. Good as gold lads too. Spud |
the vast majority of failed caliper pistons is not due to the failure of the seal, but the expansion of the inner piston (the bit you can see when you remove the brake pads) they go resuty and put pressure on the piston as it goes slightly out of shape and drags on the bore.
Sort of triggers the fit purpose question. I expected to see rusty piston or split seals, instead I found all was as it should be, no marks or scores on piston so either heat had affected it or dirt, neither would you expect in a vehicle that is built to be used off road in mud, water and snow which would normally involve salt/ grit and gravel. I suspect in my case, the worn discs and pads allowed the pistons out further than they had been previously and replacing these has the pistons working back where they should be. |
