![]() | Home > Technical > Light Steering!! |
| rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879
I would say you had a problem. Mine stays straight and feels firm and true. Maybe front suspension bushes? Im sure someone with more of an idea than me will be along to help in a bit |
| Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170
Thanks for that. MOT soon so maybe they'll pick something up then? |
Do sports have speed sensitve steering |
| muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5644
How long have you had it |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
A 4-wheel alignment check wouldn't be a bad thing. You could have an error that is symmetrical across the car so it tracks straight but is overly sensitive. Excess toe-out might cause this but then you'd also expect to see uneven tyre wear on the front shoulders. 2012 SDV6 - it's missing a couple of cylinders
I'd say check the bushes of the wishbones first and ARB bushes, then if they're all OK, go for a full 4 wheel alignment on a Hunters Geometary machine. You should als get a before and after printout so you know which bits are out. |
Thanks for the input guys, some interesting stuff there. I'll take the car for the mot soon and get under the ramp for a good look, if nothing obvious then the alignment. I don't think it's tyre or wheel related as I've recently changed them and no different. Any further advances on whether the sport has speed sensitive steering? |
Well I've since had proper 4-Wheel Alignment carried out and new ARB bushes fitted and the car does feel better, though the steering is still light. I recently drove a friends Disco 3 which felt considerably heavier and firmer??? |
Now have a my13 and the steering feels much better than my10 especially on dynamic setting |
| adigorn Member Since: 17 Mar 2010 Location: Birmingham Posts: 110
yes it does an defo worth look at |
| AndyLandy Member Since: 26 Nov 2013 Location: Bassingbourn Posts: 39
Yep, all roads, just feels light, I need to drive another similar age/spec car to get a better idea I think..... |
Unfortunately I spend most of my time on smooth roads, if anyone can enlighten me as to where in South Wales or Hereford/birmingham area I can play off road without bashing up my beloved car please let me know!! |
| All times are GMT |
