Home > Technical > Egr again..... Sorry
P7tey
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Me too Very Happy
Post #366448 Wed Dec 12 2012 9:37pm
Disco_Mikey
That is pretty cheap Shocked
Let us know how well it all fits together Thumbs Up
Post #366453 Wed Dec 12 2012 10:22pm
Mitchmx
P7tey wrote:
Thanks guys I'll get eBaying.
Did you get them? Fitted?
Mine turned up today so ill be fitting them inbetween Christmas and new year.
Post #367149 Wed Dec 19 2012 10:08pm
P7tey
Received them no probs. not sure when I'll get round to fitting but will be using the 'how to' guide on here.
Let me know how you get on!
Post #367162 Wed Dec 19 2012 11:50pm
madmackie
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
hi gents my mates egr has gone on his rrs 55 plate does anyone know of anyone who would take the job on of blanking the egr's off im based in wigan thanks pete
Post #367839 Fri Dec 28 2012 12:18pm
Mitchmx
I'm doing mine tomorrow so ill let you know how it goes.
Post #367893 Fri Dec 28 2012 6:09pm
madmackie
thanks Very Happy
Post #367912 Fri Dec 28 2012 8:06pm
Mitchmx
dint get chance to do it today because it been Censored down all day, ill post soon as i do it tho Wink
Post #367970 Sat Dec 29 2012 6:02pm
P7tey
Did mine this afternoon Very Happy
Took about 2 hours, but could have been quicker had a not had to retap a thread... Evil or Very Mad Embarassed
A couple of tips:
On the drivers side of the car there is a large plastic cover, removing this will allow you to get to EGR flange bolts with a long socket extension. Had I done this before I may have put the bolt back in straight... I also undid the U clamp that holds the 2 adjacent pipes tight, allowing them to be pushed out of the way slightly.
There is a similar U clamp holding a single pipe next to the passenger side EGR flange bolts allowing the pipe to be moved.
To remove the spindle from the EGR butterfly valve I didn't use a screwdriver as per the instructions as it all looked a bit delicate... Instead a gripped the large plastic end of the spindle with a pair of slip joints and pulled like ****. Beware as it comes out all of a sudden and you need to be holding onto the butterfly when the spindle comes out.
Finally, it would be worth ordering 4 new EGR flange bolts. I was left hunting around to replace one that had corroded about 25% through...
Has it worked? I've lost the hesitation on pull away. It feels quicker (I think Confused ). I'm hoping to improve my mpg to about 40 mpg... Whistle
Post #368038 Sun Dec 30 2012 8:46pm
Mitchmx
good good thanks for the advice. the next dry day im gonna crack on with it.
how much quicker was it? be nice if mine was a tad more responsive Wink
Post #368133 Mon Dec 31 2012 10:54pm
Disco_Mikey
Unless your EGR valves are already faulty, your car will be no quicker than before.
Post #368138 Tue Jan 01 2013 9:04am
Mitchmx
Finally got round to fitting my blanking kit today. Took me a good hour to hour and a half.
Thanks for the pointers they come in handy that butterfly shaft is a Censored to get out.
Don't think I'm going to notice any difference tho.
Look what I found when I was doing it today
[img]<img>[img]
I think replacing the intercooler pipe will sort things out.
I've heard these spit for a past time so it was no surprise.
Would anyone recommend a aftermarket one or stick with genuine. Looks a nasty job to do as well. Evil or Very Mad[/img]
Post #368187 Wed Jan 02 2013 12:07am
Bodsy
Site Sponsor
Can't see the image mitch, but I assume you have a split intercooler hose, drivers side.
They're actually pretty easy to do. Biggest pain is to get the plastic pins put from the lower radiator shroud in the wheel arch.
Undo each end and pop off the pipe and feed it out the top.
You can get silicon replacement hoses, but TBH the LR ones last 5+years anyway and are cheaper Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #368189 Wed Jan 02 2013 1:17am
garrycol
Australia
Click on the blue <img> in the post and it will magically appear. Has a split in the pipe.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #368191 Wed Jan 02 2013 5:08am
