![]() | Home > Maintenance & Modifications > llams suspension mod |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1070 ![]() ![]() |
If you go over to the Disco3 http://www.disco3.co.uk/forum/ and send a PM to GraemeS as he is the designer and builder of the LLAMS system - I am sure he can send you one if there are no local suppliers - installing the main unit is no major issue as it just plugs into the loom under the drivers dash.
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Graeme ships everywhere, no problems.
taff Member Since: 09 Jul 2012 Location: Pembrokeshire Posts: 49 ![]() ![]() ![]() |
Thanks for the photos, will get in touch with him and see if he can send one one, like the place where you hve fitted it, i have noticed that blank also.
Not as easy as it looks though |
Had email back from him, only $23 aus postage to uk! Going to see my local dealer workshop manager about fitting, dont fancy pulling interior apart will probably break something.
Should take no more than 45 min to install and calibrate. '08 RRS TDV8
