![]() | Home > Technical > hard brake pedal,car wont start. |
Had you pressed it with the ignition off ?
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4504 ![]() ![]() ![]() |
Probably a software issue. The car will not start unless the brake pedal is pressed xx%.
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
Thanks guys . Yes thats it beancounter 74. strange. SVR 2018 in Santorini Black. |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
Sign of a faulty brake pedal switch? I've seen threads where the solution was to replace the brake pedal switch so it might be a fairly common problem. That or a faulty rear brake bulb |
A rock hard brake pedal is soemthing to do with the brake pedal/servo...just like when its off if you press the pedal
HPB Member Since: 01 Dec 2012 Location: Gauteng Posts: 11 ![]() ![]() ![]() |
Have the same issue. Every morning the pedal feels very hard. Have to press really hard. My disco 4 didn't do that at all. Complaint to local dealer, but they weren't very helpfull.
