Home > General > 2008 range battery wiring
karan538
2008 Range Rover Sport TDV6 HSE Santorini Black
Hi guys, Just started my install for a sub and have nearly finished everything at the back. The problem is now i want to root the power cable from the front battery. Having a quick look at the front I cant find exactly where I'm going to root it from. Cant see the firewall that goes inside at all?
Anybody done this, got any picture or any suggestions on where to go?
thanks
Post #364868 Thu Nov 29 2012 12:16pm
simple1
The only open option is via fuse box above drivers feet. Having done installs on other vehicle the only satisfactory way is to create another hole direct to the battery and seal it well. Just a word of warning, there is lots of electrics under the seats and a sub cable creates a great deal of interference to ecu's and belt tensioners so route carefully. Also the suspension and gearbox ecu are under battery box. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #364971 Fri Nov 30 2012 8:49am
karan538
how do i accses that fuse box above the drivers seat there seems to be no way of opening it?
Post #365003 Fri Nov 30 2012 12:29pm
simple1
If you open the subsidiary box on offside, you can see the loom passing through the bulkhead. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #365005 Fri Nov 30 2012 12:40pm
