![]() | Home > Technical > 3c - FBH not starting |
Just checking, your fuel light is not on is it.?
StevoD Member Since: 01 Nov 2012 Location: Bromsgrove Posts: 42 ![]() ![]() ![]() |
Newbie to all this FBH stuff, but just to add my understanding to see if it helps (I'm sure I'll be put right if my assumptions are incorrect |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
Thank is fuel, no light there. Re StevoD, you are correct and what is not working for me is the automatic function on cold weather. Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Climate control also needs to be on for FBH to start. |
It is... Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
I assume you have it on and your battery is ok? Mike
yep Monsieur Range Rover Vogue ‘17 TDV6
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
Is the FBH attempting to start? Like this site? Buy some RRSPORT goodies to show your support! |
Actually, I don't think so! Any suggestion? Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
So, finally, quick trip to Park Royal on Saturday morning and Rob from service sort it out. Software update available for the fbh Test run it after and all good. Big thumb up |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
Did they charge you for the pleasure? |
Nope ![]() ![]() Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Good to see LPR still carrying on with good form following JT's departure |
I may have to pay them a visit then |
