Home > Technical > Today I started the car and something with the temp happened
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
The car had been standing all night and it is like 0C deg.
The temp was a little over the middle. Its like it is stuck there or something. 91 BMW 850CSI
Post #364312 Sat Nov 24 2012 3:23pm
Bodsy
Site Sponsor
possibly a faulty sensor. If you read the live values, it should point you in the right direction Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #364316 Sat Nov 24 2012 4:32pm
Fatandre
So does this mean I have to go to the service to have the faults read? 91 BMW 850CSI
Post #364319 Sat Nov 24 2012 5:06pm
Fatandre
Funny thing. Went to the car this morning and looked at the needle through the window.
It was still in the same position.
Any ideas? 91 BMW 850CSI
Post #364436 Mon Nov 26 2012 2:14am
Fatandre
Guess I am the first with that problem Sad 91 BMW 850CSI
Post #364641 Tue Nov 27 2012 12:52pm
Fatandre
Tokk the car for a drive. The meter went full up, but no warning came and the engine was allrigh.
I shut it down and the arrow fell to the middle Neutral Neutral 91 BMW 850CSI
Post #364967 Fri Nov 30 2012 9:34am
Disco_Mikey
Have you tried a hard reset, as suggested on the D3 forum?
Post #364988 Fri Nov 30 2012 11:20am
Fatandre
Well. Today I disconnected the battery. The gauge was in the same position. The needle went to the top, but no warninglight came. How does the car react when overheatiing?
That blows. Here is how the engine runs. Are the fluids ok?
&feature=youtu.be
This is after the car was driven 12 miles and was warm
Here is a picture how the needle looks when the car is off.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  91 BMW 850CSI
Post #365025 Fri Nov 30 2012 8:43pm
Fatandre
I went to the dealer and had them look at this.
They say the whole cluster needs to be replaced Sad 91 BMW 850CSI
Post #365304 Mon Dec 03 2012 7:23pm
