Home > Technical > Timed Climate - Simple Question
Cheney Jawa
Can it be activated by a LR dealer on a MY13 RRS? Owner of MY13 RRS Red Edition, Santorini Black, Ebony with Lunar, Privacy Glass & Exterior Design Pack
Post #364123 Thu Nov 22 2012 10:42pm
You'll get different opinions on the Cheney.
My dealer said no, but mse (mike) says they can.
Just depends on how amenable your dealer is, can't help to ask Thumbs Up ON THE WAY: BMW F21 M140i
Post #364126 Thu Nov 22 2012 10:49pm
Cheney Jawa
Yes sorry for the blunt question but I've tried to find the answer on here but to no avail Confused
I'm having a little 'punt' on it with the dealer at the moment with my car being in there but unfortunately they seemingly have no clue what I'm talking about Shocked Laughing Laughing Laughing Laughing Owner of MY13 RRS Red Edition, Santorini Black, Ebony with Lunar, Privacy Glass & Exterior Design Pack
Post #364132 Thu Nov 22 2012 11:10pm
mse
Yes it can, but can you get them too...possibly not...especially shatstone
There were conversations on here about it being able to
Local none dealer options Mike
2014 Facelift Discovery
Post #364134 Thu Nov 22 2012 11:11pm
Cheney Jawa
Current situation is they're fitting the steering rack and will tomorrow be connecting to their computer whereupon they'll 'have a look to see if it can be activated'
I don't hold out much hope tbh........ Neutral
Dealer is Colliers who I will say up to now have been very professional & amenable but I suppose the true test is can they actually deliver?????? Owner of MY13 RRS Red Edition, Santorini Black, Ebony with Lunar, Privacy Glass & Exterior Design Pack
Post #364143 Thu Nov 22 2012 11:25pm
I tried the same tactic when mine was recovered by LRA, they said they could, but then told me JLR said no......go figure Confused ON THE WAY: BMW F21 M140i
Post #364146 Thu Nov 22 2012 11:30pm
Disco_Mikey
It can be activated with aftermarket diagnostics, such as Autologic or Faultmate Thumbs Up
Post #364166 Fri Nov 23 2012 7:45am
StevoD
I'm having mine activated today (hopefully) by the contact MSE gave to me. Thumbs Up
Post #364179 Fri Nov 23 2012 9:37am
mse
Thats great...He will do it for you, he's a good guy - and can do it, so by this evening you will have a new toy! (if he cant, get him to ring me!)
@ Cheney Jawa if you want to know where to get it done just down the road from you, from a garage, then ill PM you
I would imagine the reason JLR changed there tune will only be the realisation that they will loose out on £1000-1500 in an option sale? Mike
Post #364199 Fri Nov 23 2012 12:38pm
This is what I suspected too Mike. Rolling Eyes Sad
Do you have any contacts down in Essex/South East you could PM me ? Razz ON THE WAY: BMW F21 M140i
Post #364202 Fri Nov 23 2012 1:00pm
mse
Im afraid not, sorry - well none that could help you with this! Mike
Post #364212 Fri Nov 23 2012 2:04pm
Tre4
2011 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
Another simple question..hopefully.
It says 20 min heat/vent however setting it for 0610 if I take a little longer getting ready in the morning it's still burning 30 mins later. What's going on ? MY11 RRS HSE
Buck Blue
Post #364311 Sat Nov 24 2012 2:19pm
mse
Are you sure it's running...eg clocks wrong?
The timer is built into the system, so unless there is a power problem it either works or not. Mike
Post #364330 Sat Nov 24 2012 9:16pm
Tre4
It's still running I can hear it and the heater light is on.
Clock is correct, unless the heater is starting late because of a heater/clock communication problem.
I take it that the whole system should switch off after 20 mins or would a fan still be blowing the warm air until the temp falls below a certain threshold? MY11 RRS HSE
Buck Blue
Post #364363 Sun Nov 25 2012 11:35am
mse
unit runs for 20 minutes, no more - it cant run any longer its not programmed to, no over-rides or options.
The only option is for it to cut off or not start early if there is a battery or fuel issue.
Mine turns itself off after 20 minutes bang on Mike
Post #364418 Sun Nov 25 2012 10:56pm
