Home > Technical > sat nav
smurf
sat nav
can someone help me,is there a re-set button for the sat nav.its seems to be out of sync,putting my location a few miles away from where i actually am
Post #363678 Mon Nov 19 2012 3:03pm
Mine did this not long after I'd got it. Exited from an underground car park and it thought I was about a mile away.
It sorted itself out when was left over night locked up. Not sure if the Sat Nav has it's own separate reset to be honest.
Failing that I suppose you could do a 'reset' of the car by way of disconnecting the battery. There are a couple of guides on here Thumbs Up ON THE WAY: BMW F21 M140i
Post #363679 Mon Nov 19 2012 3:06pm
mse
Im not sure you can reset it - but you can check its reading from the secret menu screen see its GPS is aquiring properly Mike
2014 Facelift Discovery
Post #363700 Mon Nov 19 2012 6:27pm
whippetman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Sure I found a restore default settings on a screen menu for the sat nav.MY 2011
Post #363710 Mon Nov 19 2012 7:05pm
smurf
thanks for the response so far,will look at your suggestions
Post #363720 Mon Nov 19 2012 8:46pm
saimans
I'm sure there is a manual adjustment for the current position of the vehicle. I played with it some time ago and can't remember how to get into the specific menu, but do recall being able to move the current position of the vehicle. (Whilst stationary I hasten to add).
Post #363747 Tue Nov 20 2012 3:20am
B.Safe
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
Re: sat nav
If you put an address a mile or two to a destination in the sat nav it will say "destination to close, look on the map for bla bla bla" . This is what you have to do LOOK ON THE SAT NAV SCREEN and you will see a red point on the map. You will also see all the streets. You don't get instructions "go left or go right" just go left or right like you will fallow a real map to reach the red point on the map.
I told this to my sister and she said she swered bad words for 3 yrs because she did not know Rolling with laughter
Thumbs Up /|\
Post #363752 Tue Nov 20 2012 10:11am
