![]() | Home > General > Suspension/rodent warning....! |
| Bandit8 Member Since: 20 Oct 2012 Location: Essex Posts: 99
I would never have believed a rodent would eat a rubber pipe (why??? |
| bootz Member Since: 14 Oct 2011 Location: England Posts: 86
That would explain the scrape marks on the earth wire securing nut!
| DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257
When you next fill up, check for any leaks under the car after a short drive - the elbow of the fuel return pipe appears to be tasty to rodents; I had the entire tank replaced under insurance and mine was not an isolated incident. Your compressor sounds like it may be on the way out; more likely to be due to overuse from a stuck relay or failed valve block than satisfying the dental needs of Mickey & relatives. |
thanks guys. DrLex that was what i was wondering - parts failure or rodent action.... One is covered under warrantee the other probably not! I'll see what my indy says on Monday.
