![]() | Home > General > Knocking noise |
Take a look here, i'm sure this will help |
mark hamster Member Since: 26 Nov 2011 Location: nottingham Posts: 116 ![]() ![]() ![]() |
had same problem a year ago..! had some "anti roll bar packers front and rear" fitted landrover notts about £150,been good since |
Stefan.lajszczuk Member Since: 10 Oct 2012 Location: West Yorkshire Posts: 70 ![]() ![]() ![]() |
Thanks for that.
that would be i guess a good option BUT its going to cost you a few bob..!!! |
I'll be doing the work myself, then getting a 4 wheel alignment done.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9148 ![]() ![]() ![]() |
Look on the Disco3 site. They have photo guides on how to change the ARB bushes which will help. 2012 SDV6 - it's missing a couple of cylinders
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4529 ![]() ![]() ![]() |
Just fit the shims. Much cheaper, easier and quicker to replace than the whole bushes |
Oh right, is that for the anti roll bar?
The shims cost around £1.50 from a main dealer, and there are 4 in the pack, 1 for each bush. Part number is LR012410. There is a how-to in my sig for fitting. They were fitted to a D3 in that guide, but is exactly the same procedure for a non-ARC RRS.
Nice one!
Nah. I have never seen a bush wear out again, after fitting the shims. Would be one option, or the other |
I was just wondering if I'm under the beast in any event to do it.
If you press the brake pedal sharply, and you get a single "clunk" then it will be down to front lower wishbones... |
