![]() | Home > For Sale & Wanted > WTD: Spare wheel (2005 RRS TDV6) |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
Presumably you'll need the winch cable too ?
| saty Member Since: 17 Aug 2011 Location: Beds Posts: 227
I would say I do need them bits too... yeah might drop him a line.. cheers |
| muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5644
Get a protector too from Ray/RLD |
Hi mate, what is the dfference between this and the one Dan (duckworths) sells? cheers |
Dan sells a revised winch but ray sells a cover that protects the wheel and winch |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
What size spare do you need? |
Cheers muddywheels .... so would it be wise to get both the revised winch and this cover? Hi, I am currently on 20's but with it being a spare I would imagine any size is ok... What have you got? Cheers |
Saty - I looked at revised winch but kept my original winch as it was still working and covered it with the protector |
Thanks Muddy Wheels that sounds like a plan.. firstly need to look under the car itself and see if I need a winch and then get a spare wheel and Ray protector.. Now I have a dilemma.. do i get a new 20" wheel (£300 odd) to match or i have seen a basic 17" on ebay with a tyre for £60 odd... |
Check you can fit a 17" on yours before you buy it and be careful buying secondhand tyres - if it is over 5 years old it may be cracking even if it has good tread |
Good point about the tyre MW.. What is the standard spare.. is it alloy or a space saver type? True say about I could end up with my own wheel from ebay I am speaking to Dan at the mo, so might end up with something better .. fingers crossed cheers |
Standard spare I believe is a spacesaver 19" Saty |
Standard spare is a 19" but unless you match alloy exactly and the tyres you have it will still need to be treated in same way even if full size for safety - ie speed, etc |
Thanks chaps... |
| All times are GMT |
