![]() | Home > Technical > Brembo fitting on hse |
Jonesyscoob Member Since: 21 Oct 2012 Location: Birmingham Posts: 95 ![]() ![]() |
Thanks although cant find any pics of his or the how to paint?? |
spud1234 Member Since: 28 Sep 2012 Location: Co Durham Posts: 83 ![]() ![]() ![]() |
http://www.rrsport.co.uk/forum/post340396.html#340396
Also take a look here. |
Mitchmx Member Since: 22 Jul 2012 Location: Bristol Posts: 156 ![]() ![]() |
Great links.
I was talking to someone today about these brakes and they said about the master cylinder being man enough to cope with the bigger calipers. Dose anyone know if the tdv8 master cylinder is the same? Other wise if it can't push enough fluid through then you will get a spungy peddle. I might try and mesure the volume of the standard pistons and the brembo pistons then see how much differance the is. |
Decided to do mine red in the end
Nice job.
Brembo sticker |
