![]() | Home > General > Number of faults & Warranty wont honour ANY of them ! &l |
Mozilla Member Since: 28 May 2012 Location: London Posts: 30 ![]() ![]() |
You know you get the sneaky feeling when the person on the other end of the line breathes through his teeth and gives you the garbage "im afriad thats wear and tear and not covered..." |
AndyKay Member Since: 14 Jan 2012 Location: Leeds Posts: 226 ![]() ![]() ![]() |
it says "Vehicles up to Five years" so I'm surprised it's still covered if yours is a 2006 RRS HSE TDV6 Autobiography |
It was at the point when the warranty was taken out by the previous owner, at which was point it was around 3 years old and much less than 40k miles. |
Leaking front diff and bushes are known faults so I would jump up and down about those, bushes are wear and tear although ball joints are known issues which land rover won't stand over. Not much help but I got new diff from LR at small contribution from me due to previous leak causing failure. 2x TDV6. SE and HSE. Both returned to sender with issues👀
