| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > Autobiography exhaust tips for non PDF exhaust help!? |
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738      | Tim, the exhausts changed late 2010 to straight tailpipes, i'm sure if you just cut off the bit that is pointing downwards you should be fine, but i would place the exhaust tip along side your exhaust pipe first just to see if it is still going to be long enough to attach the A/B tip without it been too short. | ||
|  Thu Oct 25 2012 6:53am |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355    | Be aware the older cars had downward firing exhausts for a reason   | ||
|  Thu Oct 25 2012 10:21am |
| timmymagic46 Member Since: 03 Oct 2012 Location: London Posts: 14      | Interesting as I assumed all 2010 onwards facelift cars had the new exhaust... My speck sheet even says it is a PDF car! Tim Boler | ||
|  Thu Oct 25 2012 7:18pm |
| Ady 555 Site Moderator Member Since: 12 Dec 2010 Location: Good old yorkshire Posts: 8738      | Do you mean DPF   | ||
|  Thu Oct 25 2012 7:57pm |
| timmymagic46 Member Since: 03 Oct 2012 Location: London Posts: 14      | Yeah, that's he one  | ||
|  Thu Oct 25 2012 7:59pm |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355    | Sorry my mistake I thought you were fitting new exhaust tips to a pre-facelift   | ||
|  Fri Oct 26 2012 7:55am |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | its not uncommon for some early cars to carry some late spec kit - it could be your exhaust was such a left over item...or the wrong one fitted by someone else.
|  Fri Oct 26 2012 8:40am |
| Posting Rules
