![]() | Home > Maintenance & Modifications > Coolant Leak |
RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80 ![]() ![]() ![]() |
Got a low coolant warning the other day, upon inspection I've found a damp area with drip on the underside of the car behind the tow eye cover on the right chassis leg looking from the front. Can't see where the leak is coming from, looked from top and bottom! Anyone any ideas what could be leaking? 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Rover T Member Since: 11 Oct 2012 Location: West Posts: 11 ![]() ![]() ![]() |
My RR had a leak from the lower front N/S area. When i checked it I couldnt find anything obvious.
thanks for the reply. I've taken the cover off in the N/S Wheel arch and reveiled the botom hose which was wet but it seems to becomin g from a smaller pipe above. Not sure what this pipe is. Got 3 months warrenty on the car so think i may take it back to the dealer and get it sorted propoerly. Not a lot of room in there to work!!! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Any further developments?? |
Car booked in with garage to repair under warranty. Leak is very slow so not overly concerned at minute. Just need to keep an eye on it 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Anything found?? |
