Home > Maintenance & Modifications > engine oil top up
jonnygo
England 2007 Range Rover Sport TDV8 HSE Java Black
engine oil top up
Just dipped my engine oil and its in the middle of the plastic thingy majig.
How many ml to take it to full?
TDV8
Cheers TDV8 Java black/Ebony black
Post #360060 Thu Oct 18 2012 5:09pm
Paddi
Probably about a litre; but put half a litre in first let it settle for a few minutes then dip it again. It's a big old sump - takes nearly 10 litres to fill it up from empty.
If you last checked it ages ago then fine (but shame on you) Laughing . If it is losing oil have it checked out. 2008 MY Java Black TDV8 HSE
Post #360066 Thu Oct 18 2012 5:39pm
jonnygo
Cheers pal, I did dip it in june and was full so left it a while lol Whistle
Defo not losing any oil. TDV8 Java black/Ebony black
Post #360075 Thu Oct 18 2012 7:07pm
oldcro
Scotland
Be careful you do not overfill.
Post #360088 Thu Oct 18 2012 9:38pm
jonnygo
Exactly why i'm asking pal.
Not had to top up yet,only had it 4 months so not sure on measures yet.
My last car needed 250ml from halfway to full.
Thought the wealth of knowledge on here would stretch to a top up 60 odd views no answer lol
I'll ring duckworths in the morning TDV8 Java black/Ebony black
Post #360096 Thu Oct 18 2012 10:31pm
Paddi
Charming. Give someone the advice they are asking for and they say they'll call Duckworths. We could have just told you to RTFM. In case you don't have one - It says add half a litre if the level is higher than midway between the marks and a litre if it is less than that and then re-check after a few minutes. 2008 MY Java Black TDV8 HSE
Post #360153 Fri Oct 19 2012 4:27pm
jonnygo
Thumbs Up Paddi I did RTFM ayfa ltr as you said lol
Thank you Bow down Laughing TDV8 Java black/Ebony black
Post #360157 Fri Oct 19 2012 4:39pm
