![]() | Home > Wheels & Tyres > Front wheels keep getting filthy! |
Ok, no question is stupid...so I'll assume it's sincere.
spud1234 Member Since: 28 Sep 2012 Location: Co Durham Posts: 83 ![]() ![]() ![]() |
Thanks, really was a sincere question as I've never had it happen to me before and thought I had a problem. Now I feel stupid |
I did wonder...don't worry, no question is stupid.
moparmuff Member Since: 25 May 2012 Location: S. Bucks Posts: 96 ![]() ![]() ![]() |
"- sealing them makes it less obvious and easier to clean"
Also changing the front brake pads may help, a previous owner might of put some cheap pads in before he/she sold the car on. How long have you had the motor? Some pads give off more dust than others, but agree with the comments above. Do you use tyre gel on your tyres? |
Had the car a year, pads were changed just before I got it for the last MOT. I don't use gel but do have laquer that I will put on the alloys at the weekend. I have had an X5, 350Z and never had this bad a problem before, I may change the pads too just in case as it looks terrible after a couple of weeks. Thanks. Spud |
After a couple of weeks |
Knew you'd get me on that. |
Kensta Member Since: 17 Feb 2011 Location: North east Posts: 702 ![]() ![]() ![]() |
Silly question but have u checked you've still got the brake shields fitted behind the disc? Some people remove them and that may cause more muck flying round, also as Ady says cheap brake pads cud b the problem Java black 2006 |
Cheap pads will definitely do it, doubt there's a mechanical problem (like brake binding) but always worth a check.
Discovery1953 Member Since: 07 Aug 2011 Location: Sandridge, Wilts. Posts: 127 ![]() ![]() ![]() |
Which Autoglym in particular ![]() RAM Cobra, Aluminium body, 7 litres and +500 BHP - SOLD |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Spud
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5642 ![]() ![]() |
swmbo has a mini and it is a nightmare - far worse than the RRS for brake dust |
Mini's are renowned for have crap brake pads in from the factory, you are lucky to get 20,000 miles out of a set |
